HP Office jet 8702, installed 4 HP new cartridges, all 4 show empty and can not get past this error message. I have tried all reinstall with new, turned off, plugged in and  out both machine and wall sockets. Tried the hard restart. Installed all new updates and drivers for this machine. All was working fine till the last new cartridge replacement. Have always used HP replacements.  Also reinstalled printer.  Also all looks good inside. Any help much appreciated. Thank you,
1 REPLY 1
Hi @50Sharon,
Thank you for posting your query, I will be glad to assist you.
I see that you are facing an issue with your Printer that has a supply system error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
