To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
HP ENVY 6055e All-in-One Printer
HP smart shows all okay on printer but it will not print. red
1 REPLY 1
Hi @tim212,
If your HP ENVY 6055e All-in-One Printer is showing a red light and won't print despite the HP Smart app showing it as okay, here are some steps you can try.
Check the Cartridge Status:
  • Ensure the ink cartridges are properly installed and not empty or low on ink. The flashing red light often indicates an issue with the cartridges.
  • Open the front access door and make sure both cartridges are seated correctly.
  • If the ink levels are low, try replacing the cartridges.
Clear Paper Jams:
  • Check for any paper jams or obstructions inside the printer. Remove any stuck paper or debris.
  • Make sure there are no torn pieces of paper left inside after clearing the jam.
Reset the Printer:
  • Unplug the printer from the power source and leave it unplugged for about 1-2 minutes.
  • Plug it back in, power it on, and try printing again.
Check for Firmware Updates:
  • Open the HP Smart app and check for any available firmware updates for your printer. Install any updates if available.
  • Outdated firmware may cause communication or functionality issues.
Reinstall the Printer Driver:
  • Sometimes, reinstalling the printer driver can resolve issues.
  • Go to your device’s Control Panel > Devices and Printers > right-click on your printer and select Remove device.
  • Then, reinstall the printer through HP Smart or your system's Add a Printer function.
Factory Reset the Printer:
  • If none of the above steps work, consider performing a factory reset on your HP ENVY 6055e printer. This will restore it to its original settings, which might help resolve the issue.
    • To perform a factory reset, press and hold the Wireless and Cancel buttons on the printer at the same time for about 5-10 seconds until the printer restarts.
Try these steps and see if the red light stops flashing and the printer resumes normal operation.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
