Hp 7001 smart tank worked last night. In plugged it in the middle of night because it started making noises. Power on today and all lights blink. Tried unplugging and holding power cord to reset power but just does same thing every time. If I press power button while it’s on it shuts off and comes back o. And continue to blink all lights
1 REPLY 1
Hi @Sza77,
I'd be glad to help you!
I'm sorry to hear about the issues with your HP Smart Tank 7001—it's frustrating when a reliable device suddenly stops functioning properly.
If all control panel lights are blinking, follow these steps.
Perform the following tasks in the order given. Use the printer after each task to see if the issue is resolved.
Reset the printer
  • Reset the printer to recover from printer errors or failures.
  • Press the power button to turn off the printer. If the printer does not turn off, disconnect the power cord from the printer.
  • Unplug the power cord from the power source.
  • Wait 60 seconds.
  • Connect the power cord directly to a wall outlet and to the printer.
  • Turn on the printer to complete the reset.
If the previous steps did not resolve your issue, contact HP Customer Support for further assistance.
Go to HP Customer Support - Contact.
Enter your product serial number to view warranty status and to change your location, if necessary.
Select a support option. If you are in Asia Pacific, you will be directed to a local service center in your area.
You may also refer to Blinking Lights.
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
