Officejet Pro 8600 Premium
Windows 7
Is there a way to print 11 X 17 size paper with this printer.
No,
The printer supports up to the Legal paper size, It does not support bigger sizes as A3.
You ay find the paper handaling specifications below:
http://support.hp.com/us-en/document/c02858465
Shlomi
Click the Yes button to reply that the response was helpful or to say thanks.
If my post resolve your problem please mark it as an Accepted Solution 🙂
3 REPLIES 3
No,
Shlomi
Thank you.
Try this...
1. Start Menu
2. Device and printers
3. Choose HP printer (ex. HP OfficeJet Pro K8600)
4. Right Click at printer
5. Select "Advance Options" tab
6. Press "Print Processors" buttom
7. Select "WinPrint" and "RAW" Option
8. Acept changes
I think this will solve your problem.
Regards
Kervin P.
