hi there,
I am an InstantInk customer.
Have had a problem with the color cartridge, displaying an error "The indicated cartridges are not communicating correctly with the printer. If this problem persists, replace the cartridges".
I have attempted all the different advice options to solve it like a printer reset (hard unplug from electricity), cleaning the cartridge but have had no luck as error persists.
I believe the cartridge is faulty. Can you please help processing a replacement asap? I'm a teacher so my printer is very important for me.
Thanks
1 REPLY 1
Hi @mz85,
I understand that you are getting a cartridge error, I am glad to assist you.
Reset the printer
  • Reset the printer to recover from printer errors or failures.
  • If your printer has a rechargeable battery, remove it.
  • With the printer turned on, disconnect the power cord from the printer.
  • Unplug the power cord from the power source.
  • Wait 60 seconds.
  • Reconnect the power cord to a wall outlet and to the printer.
  • HP recommends plugging the printer directly into a wall outlet.
  • Turn on the printer to complete the reset.
Clean the ink cartridge and printhead electrical contacts
  • Remove any debris or buildup from the contacts on the cartridges and in the carriage.
  • Open the door or lid to the cartridge access area. Wait until the carriage stops moving before continuing.
  • Remove the cartridge indicated in the error message from the carriage.
  • Wipe the copper-colored contact on the cartridge with a lint-free cloth.
  • Place the cartridge to the side with the contact facing upwards.
  • Wipe the contact inside the printhead with a lint-free cloth.
  • Reinsert the cartridge into its color-coded slot, and then press down on it until it snaps into place.
  • Repeat these steps for any other cartridges indicated in the error message.
  • Close the door or lid to the cartridge access area.
  • Here is the HP document for further assistance:- Click here
I hope this helps.
Rachel571
HP Support
Sneha_01- HP support
