HP Smart Tank 580 All-in-One Printer
Please help my hp tank 580 E1 error
1 REPLY 1
Hi @Manprit,
An E1 error on an HP Smart Tank 580 typically indicates a problem with the printhead or ink system. Here’s how you can troubleshoot this error.
  • Check Ink Levels: Ensure that all ink tanks are properly filled and not empty. Refill any empty tanks if needed.
  • Inspect Ink Cartridges: Open the printer and check if the ink cartridges are correctly installed. Remove and reinstall them to ensure they are seated properly.
  • Clean the Printhead: Sometimes, cleaning the printhead can resolve errors. Use the printer’s built-in cleaning function from the control panel or software.
  • Check for Obstructions: Look inside the printer for any paper jams or obstructions that might be causing the error. Clear any debris or obstructions you find.
  • Restart the Printer: Turn off the printer, unplug it from the power source, wait for about a minute, then plug it back in and turn it on.
  • Update Printer Firmware: Ensure your printer’s firmware is up to date. Check the HP website for any available updates.
  • Reset the Printer: If none of the above steps work, you might need to perform a factory reset.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
