HP ENVY 6055 All-In-One Printer
I have tried every suggestion from the Virtual Assistant and searched these posts, but cannot resolve my issue. When turning on the printer, the yellow "i" light flashes. There are no error codes. Cannot put printer in wireless setup mode; holding wireless button on back has no effect. Am able to print over a wired PCL connection to computer, but cannot print wirelessly.
1 REPLY 1
Make sure the router and computer or mobile device are turned on. Make sure the computer or mobile device is connected to the same wireless network to which you want to connect the printer. Set up the printer, load paper into the input tray, and install the ink cartridges.
Regards,
Will
