HP Officejet Pro 8630 e-All-in-One Printer
When printer is turned on, the error message "There is a problem with printer or ink system".  Any one know what it takes to fix this issue?
3 REPLIES 3
Hi @inreco,
I see that you are facing an issue with your printer that has a ink system error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
Thanks Erwin but that didn't work.
Hi @inreco,
I am sorry to hear that the above steps did not help much but i do appreciate your efforts in performing the troubleshooting steps.
Pefer to the steps on this link to restore factory defaults and let me know if that resolves the issue.
I hope this helps.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
