hp8600 pro
After working great, for unknown reasons its blue wireless indicator led stays off
Printing from the laptop is not working, printer can not be found
After resetting the printer, and running the Setup-Wizard, we now lost printing from iPad and iPhone
I have printed a testpage, it shows 100% positive result on the wireless connection and a strong signal strength
What am i missing ?
2 REPLIES 2
If the blue wireless icon on the printer is off then your printer isn't connected to wi-fi. Once more from printers control panel under setup menu select Wireless setup wizard and give it another try.
My profile on LinkedIn
Thank you for your reply Valsimot, but i have tried that multiple times, last time i also did a reset on the router, then resetted the printer and ran the wizard, the blue led did not even blink.
Before all that, it would still accept jobs from ipad/iphone (without active blue led)
*made me wonder if the blue-led might be broken (seems unlikely), and maybe should focus on the laptop?
At start, before router reset and after, the testpages showed "100% working" status?
