RUNNING WINDOWS 10, HP OFFICEJET 8020 PRO SERIES PRINTER
1 REPLY 1
Hello judy-m2 ,
Welcome to the HP Support Community!
Seems that an entry of the spooler is defective.
- click on START - Programs - Accessories
- right-click "Command Prompt" and select "Run as Administrator"
- type the following commands in a line one after the other and confirm with ENTER afterwards:
sc config spooler depend= RPCSS {Enter}
[The space between "=" and RPCSS is mandatory].
exit {Enter}
- now perform a reboot
Is it working again now?
Kind Regards
Andr-1611
If my post resolved your problem please mark this post as an "Accepted Solution".
Or click on the YES button to reply that the response was helpful and/or to say “Thank You”.
I'm not an employee of HP, I'm as volunteer here.
