310 ink tank printer
The black ink refill bottle refuses to drain into the tank. Initially all the four bottles drained sequentially without a problem. I did not use the preinter for 3 months. When I wanted to print I found that ink had dried up. Trying to fill up the black ink tank as per procedure but it refuses to drain! Anyone else had this peculiar problem?
1 REPLY 1
@yeti3
Welcome to HP forums, I see that
I am sending you a private message. Please check the mailbox icon at the top-right corner of this screen.
I hope this helps resolve this issue completely
Cheers.
Sandytechy20
I am an HP Employee
