HP ENVY Photo 7155 All-in-One Printer
I have gone through the wifi password is correct, I just printed on it days ago and it was just fine.  WIFI light keeps blinking and I called our WIFI and they say its the printer.  I know I have print jobs waiting to be printed and I'm not sure what to do.
1 REPLY 1
Hi @NCPlanner,
I'd like to help!
To be able to answer you effectively, we need some information.
Make sure, your printer and your device are on the same network as 2.4GHZ only.
Is it a private (Home network) or a public Wi-Fi connection? Wi-Fi direct? Or Hotspot?
What device are you using the printer with a Windows computer, Mac, Android, or iPhone?
Follow the steps below to disable Wireless on the printer-
Go to Setup > Network Setup > Wireless Settings > Wireless ON/OFF
Now, the wireless light will stop blinking.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping
Nal_NR-Moderator
I am an HP Employee
