My HP Color LaserJet Pro MFP M283cdw paper tray will not go back in
1 REPLY 1
@GaStow, Welcome to the HP Support Community – it’s great to have you here!
I appreciate you taking the time to share your question. I'm more than happy to assist with this and provide a solution that works for you.
If your HP Color LaserJet Pro MFP M283cdw paper tray won’t slide back in, it’s often due to a misalignment or obstruction. Here are some steps to help you resolve the issue:
Turn off the printer and unplug it from the power source for safety.
Remove the paper tray completely:
  • Gently pull the tray out until it stops.
  • Lift slightly and pull it out fully.
Check for obstructions:
  • Look inside the tray slot and the tray itself for any jammed paper, labels, or debris.
  • Also check if any paper guides are sticking out or misaligned.
Inspect the paper guides:
  • Ensure the length and width guides in the tray are properly aligned with the paper size.
  • Misaligned guides can prevent the tray from sliding in.
Check for overfilled tray:
  • Make sure the paper stack is below the maximum fill line.
  • Remove excess paper if needed.
Reinsert the tray:
  • Align the tray with the rails and gently push it in.
  • If it resists, don’t force it, double-check for alignment or obstructions.
Power on the printer and test.
HP Color LaserJet Pro MFP M282-M285 User Guide - ENWW
I hope your issue is now resolved. If not, feel free to reply and we’ll continue helping until everything’s sorted!
If the post helped, please click “Accepted Solution” to help other users easily find it. And if you’d like to say thanks, just tap the “Yes” button!
Cheers,
Max3Aj
HP Support
