Windows 11 Support Center. -
- HP Community
- Printers
- HP Laserjet Pro Error Code 59.F0 - won't print; model MFP M4...
04-08-2024 02:37 PM
Product: HP Color LaserJet Pro MFP M477fdw
Operating System: Microsoft Windows 11
Printer won't print, instead displays Error Code 59.F0. Turned off and RESET as displayed... no change. Still will not print.
1 REPLY 1
04-08-2024 02:57 PM - edited 04-08-2024 03:00 PM
Download the instructions and the file that fixes the issue here: https://www.dropbox.com/sh/bb152avrl4ldbvq/AAAwFzMKOCxgKKrIPDgiL8C2a?dl=0
See this old topic if you want to reassure yourself that the fix works https://h30434.www3.hp.com/t5/LaserJet-Printing/Printer-Error-59-F0-can-t-print/td-p/7447994
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
Ask the community
