Windows 11 Support Center. -
- HP Community
- Printers
- HP Mobile 100 does not recognize color print cartridge
12-17-2017 01:33 PM
I have three HP officeJet 100 mobile printers. Two of them will not recognize the color cartridge. I have cleaned the contacts yet they still give a blinking light.
Anything else I can do.... I am able to take them apart and it appeares all the circ boards and wiring is good.
Thanks,
Larry
12-18-2017 05:31 PM
Hi @goldline1,
Thanks for engaging in HP support Forums! This is a wonderful location to converse with the community, get assistance and find tips! I understand you are having issues with the HP Mobile printer not detecting the color cartridge. Don't worry as I have a few suggestions which should help you resolve this issue.
To provide you with an accurate solution, I'll need a few more details:
Did you replace the cartridge recently?
Did the error appear all of sudden while using an existing cartridge which worked fine earlier on the same printer?
In the meantime, let's try these steps here:
Perform a Hard reset on the printer and make sure that the printer is connected directly to the wall outlet and not to the surge protector.
Remove all the ink cartridges and then try to perform a hard reset on the printer.
With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
Remove USB cable, if present.
Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord and then plug back the power cord to the printer.
Turn on the printer and wait till warm-up period finishes and the printer is idle.
Now insert the ink cartridges and then try to print a test page and check if it works.
Next thing, I would suggest here is to follow all the steps suggested in the support document for - HP Officejet 100 Mobile Printers - Blinking Lights
Please let me know if this resolves the issue, or if you require further assistance!
Eagerly waiting for your response!
I hope you have a good day ahead,
And Feel free to ask your queries as this forum has some of the best people in the world available and ready to help.
Regards,
Jeet_Singh
I am an HP Employee
12-18-2017 09:44 PM
Thank you so much for the response and suggestions.
Yes, this started relativly suddenly and the cartridge is recognized by the one HP 100 that is working properly. This tells me it is not a cartridge issue.
I will do the re-boot, per your suggestion, and let you know the outcome... fingers crossed 🙂
Larry
12-19-2017 12:10 PM
Hi @goldline1,
Thank you for replying,
Please take your time and get back to me with the results,
I'll be awaiting your response and would be glad to help.
Feel free to post your query for any other assistance as well,
It's been a pleasure interacting with you and I hope you have a good day ahead.
If you wish to show appreciation for my efforts, mark my post as Accepted Solution.
And click on the Purple Thumbs up icon at the bottom of my comment.
Regards,
Jeet_Singh
I am an HP Employee
