Windows 11 Support Center. -
- HP Community
- Printers
- HP OfficeJet Pro 6978 will not print duplex from Word on mac...
03-30-2018 10:16 PM - edited 03-30-2018 10:29 PM
At least in MS Office 2011, for both Word and Excel, duplexing is not achieved by a checkbox in the main Print menu, as it is for the PDF work-around (which also works, but it's an extra step).
If you want to print double-sided, you need to use the "Layout" dropdown menu in the main Print menu. There you will find a further Two-Sided dropdown menu. Use "Long-Edge Binding" if you want both sides to have the same orientation.
(Short-Edge Binding" will put the top of one page even with the bottom of the second.)
See this HP support page for further documentation.
04-29-2018 04:31 PM
Let's try this again: I used this solution that "cl851"contributed earlier in this thread, and it worked great:
“Go to Microsoft Word and click print. Under printer click add printer. Click on your printer and give it a new name. Then under “use” click on select software. Scroll down to HP Officejet 6800 and click ok. Click add printer and when it says that you are adding a duplicate printer just click ok. For some reason when the “new” printer is selected it works.”
09-10-2018 05:52 PM - edited 09-10-2018 06:00 PM
Same problem: everything would print two sided EXCEPT MS Word from my Mac laptop.
SOLUTION for me was RESET PAPER SIZE under PAGE SETUP: File --> Page Setup --> Paper Size ---> ( then select from drop down menu) US letter.
For some whacky reason, the paper size had changed to index card letter. (I think this happened after I printed some 8 1/2 x 11 card stock). I finally got an error message that "two sided printing is not available for Card Index Letter. Anyway, as soon as I selected US letter for paper size, no problem with two sided printing from MS Word. (And, as soon as I amde the selection to US letter, Card Index Letter disappeared from the drop down menu selection.
I hope this helps!
12-05-2018 10:08 AM
I have an OfficeJet Pro 6978 with the same problem: suddenly after a year and a half the duplex option doesn't show up in the print menu. I've tried all the solutions everyone has posted on this string, but nothing has worked. Are there any other options?
12-05-2018 11:29 AM
Hello,
Thank you for posting in this thread. Unfortunately, based on when the last response was made, I have closed this thread to help keep comments current and up to date. I recommend starting a new thread for your issue by clicking here: https://h30434.www3.hp.com/t5/forums/postpage
To be more helpful with your post, you may add key information if you wish:
1. Product Name and Number (please do not post Serial Number)
• Example: HP Pavilion DV2-1209AX or HP Deskjet 3000 Printer CH393A
2. Operating System installed (if applicable)
• Example: Windows XP, Windows Vista 32-bit, Windows 7 64-bit
3. Error message (if any)
• Example: ""Low disk space"" error in Windows
4. Any changes made to your system before the issue occurred
• Examples: Upgrading your Operating System or installing a new software; or installing new hardware like a printer, modem, or router.
If you have any other questions about posting in the community, please feel free to send me a private message.
Thank you.
- « Previous
- Next »
