To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
OfficeJet Pro 8710
About a month ago the printer started crashing every few hours.
  • firmware is current
  • no pending jobs from any PC print queues
  • With the unit unplugged, opened all panels, looked for debris, and then blew out with canned air
  • All three color cartridges were low, so I replaced them and reseated the black cartridge
A full factory reset may have resolved the issue: hasn't crashed in 24 hours
8 REPLIES 8
I’m having the same issue, unplugging from the what has had no effect. Will have to try factory reset. Seems to be a common problem these days, HP any proper solution for this?
I only found one reference to a 'B8' code - on this forum - but that referenced a problem with an obstructed carriage. Since the crashes never occurred during active print jobs but only after the printer sat idle for a few hours, my theory was that there was something up with the web services. My printer is out of warranty so I couldn't submit a support ticket to HP.
Update: two days without a crash after I did a "Restore Factory Defaults".
Good luck!
What do you mean a Factory reset on printer.  How do you do that
I have the same issue.  I push the power button and, after restart, everything works fine.  After a few hours of inactivity, the same error reappears.   I'm trying the factory reset.
Factory reset has fixed the issue for me, been fine for quite a few days now.
Do factory settings reset through your printer, should resolve problem. My 8710 is working properly now.
Found factory settings reset on printer . Resolved
