HP Officejet 4630 will not turn on. Have seen green internal Power supply is on but the printer will not turn on. Any ideas?
3 REPLIES 3
Hi @DD1019
I see that you are facing issue.
I've sent you a private message with the instructions. In order to access your private messages, click the private message icon on the upper right corner of your HP Support Community profile, next to your profile Name or simply click on this link
I hope this helps.
Treeko
HP Support
I am an HP Employee
@Treeko, I am having the same issue, can you please send me a PM regarding possible solutions as you did for @DD1019?
Thanks!
Hi @DD1019
I hope this helps.
Treeko
HP Support
Hi @haw1387
I hope this helps.
Treeko
HP Support
I am an HP Employee
