HP Officejet Pro 6230
Microsoft Windows 7 (32-bit)
My officejet pro 6230 has all lights above the ink colors flashing in a pattern slowly from left to right. The printer will not connect to our wireless network and is not recongnized by the computer. This all happened after replacing all the print cartridges. Any help would be greatly appreciated. Thanks
Hi User,
It seems that your have print head issue.
HP has published the document for this issue. Please follow the document to resolve the issue.
http://support.hp.com/us-en/product/HP-Officejet-Pro-6230-ePrinter-series/5390318/model/5390319/docu...
Hope it will help to resolve the issue.
Click on the "Thumbs up"button on the bottom to say "Thanks"
Please mark the post that solves your problem as "Accepted Solution"
(Although I am employed by HP, I am speaking for myself and not for HP)
2 REPLIES 2
Hi User,
Hi @mbgintlh,
Before you to go HP customer service, I think what you can do from your side to go to Setup Menu and do a Clean Printhead first to see if the problem can be sovled or not.
This is an easier way so that you can save your own time for your personal things.
There are several ways of checking the printer status, here are 2 basic ways:
1. Go to setup menu, select print report and print the status report. 2. You can also go to browser and type in the IP address if your printer is connected to the network.
Hope this can help you out, have a nice day:)
PLEASE Click the thumbs up + button if I have helped you. Mark Accepted Solution if I solved your inquiry.
I am an employee of HP. I am speaking for myself and not for HP.
Please click on "Thumb Up" button to say thanks.
Please mark this as "resolved solution" if my answer resolved your problem.
