HP Officejet Pro 6978
I have replaced all with genuine HP cartridges, and have new paper in the tray.  It sounds and acts like it is copying or printing but pages come out with no ink.  Suggestions?
2 REPLIES 2
HP can you help please?
@VBUDD
Welcome to the HP support community.
I understand that the new cartridges are not working, and I am glad to assist you.
Clean the printhead
From the printer control panel, open the Setup menu.
Open the Printer Maintenance menu.
If necessary, open the Tools menu, and then touch Clean Printhead.
Make sure the ink cartridges are properly vented and seated correctly
Turn on the printer, if it is not already turned on.
Open the ink cartridge access door.
The carriage moves to the center of the printer.
Open the cartridge access door
Wait until the carriage stops moving before you continue.
Press the tab inward on the front of the old ink cartridge to release it, and then pull up on the ink cartridge to remove it from the slot.
Pushing the ink cartridge inward and then pulling up to remove it
Examine the vent area above the HP logo on the top of the ink cartridge.
Image: Examine the vent area on the top of the cartridge
If the ink cartridge still has the orange pull-tab attached, pull to remove it.
Image: Remove the orange pull-tab
If the vent is clogged, use a straight pin to gently remove excess adhesive from the vent.
Clogged vent
With a straight pin, gently remove excess adhesive from the vent
Unclogged vent
Turn the ink cartridge so that the ink cartridge contacts face downward, and then match the label color with the color dot on the carriage.
Slide the ink cartridge into its slot, and then gently press the ink cartridge down until it snaps into place.
Reinserting the ink cartridge
Repeat these steps to inspect the vents on each of the ink cartridges.
Make sure each ink cartridge is firmly installed in its slot. Run your finger along the top of the ink cartridges to feel for any that are protruding, and if any are, press down firmly until each ink cartridge snaps into place.
Close the ink cartridge access door.
Closing the ink cartridge access door
Refer to this HP document for further assistance:- Click here
Keep me posted.
If this helps, please mark the public post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
