Windows 11 Support Center. -
- HP Community
- Printers
- HP Officejet Pro 8710 Output tray extension does not automat...
07-05-2021 11:03 AM
Dear All
I would like help with the issue below.
When I purchased my Officejet Pro 8710 a few years ago, it was opening automatically the output tray extension (arm) everytime I was printing. This helped particularly in paper not dropping on the floor after being printed.
For some time (>6m) I did not use the printer after that. Now when I resumed using it, I noticed that I need to open the tray extension/arm manually as it does not come out automatically anymore when I print.
I tried so far the following:
- Removed the output tray and greased with food grade grease the rails on the tray extension as it was moving very difficultly - i did put little grease and made sure none leaked.
- Checked that nothing is stuck underneath after removing the paper tray too and inspecting the bottom - in fact I did not notice any levers which should be pushing the tray out so started wondering how it was opening automatically before..
- Power restarted the machine - removed the power cord from the back, waited for more than 30s and then plugged it back in directly connected to the socket without any surge protectors etc
- Updated to the most recent firmware
None of the above solved the problem.
Apart from this, the printer operates normally, prints/scans like new and paper moves without jams.
Thanks in advance for your help.
07-09-2021 07:13 AM
@Phillip33, Welcome to the HP Support Community!
I understand the paper extender in the input tray is not ejecting automatically. I appreciate your efforts in trying to resolve this issue by performing the necessary troubleshooting steps.
There are no other steps that can be performed to resolve this issue.
I'm afraid this is a mechanical failure. Please reach out to the HP Technical Support team in your region regarding the service/replacement options.
You may create a case on the website to obtain a case number if required. Kindly watch this video to know how.
Keep me posted for any other assistance.
Have a great day!
KUMAR0307
I am an HP Employee
