HP Officejet Pro 8710 AIO
Trying to install printer, asked for WSP PIN but can't find it anywhere on the printer or with the packaging.  I cant get my printer to work.
The WPS PIN would be found on your router, typically on the label on the bottom.  You may also have a WPS button on the router that you could press for a few seconds to enable the printer and router to automatically connect.
Bob Headrick,  HP Expert
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click "Yes" to the "Was this post helpful" question.
3 REPLIES 3
 Bob I pressed the WPS on my router and still it asked for my WPS PIN can you please help
The troubleshooting steps in the post here may help resolve the issue with the setup requesting a WPS PIN.  Generally WI-Fi direct will not be how you want to connect the printer, I would suggest connecting to your router instead.
