Windows 11 Support Center. -
- HP Community
- Printers
- Hp Officejet Pro 6835, Problem with Printhead
08-04-2019 11:02 AM
I wanted to print a document out today but the paper came out clean. Afterwards, there was a error message that said " There is a problem with the printhead.." Can anybody tell me what to do?
- Let me know if this product is available for a recall, the warranty has expired. The previous recall was in 2017.
PS>>> I looked this up online and I found that there was a recall for the Officejet Pro 6835 due to printhead issues. I'm concerned because it does say that the recall was in 2017. I hope I can get this printer fixed.
08-06-2019 11:44 AM
@Jason-_-H, Welcome to the HP Support Community!
To check the products which are in HP Recall list, refer to this document. Unfortunately, the HP Officejet 6835 is currently not in the list.
Reset the printer
- With the printer turned on, disconnect the power cord from the rear of the printer.
- Wait at least 60 seconds.
- Reconnect the power cord to the rear of the printer.
- Turn ON the printer, if it does not automatically turn on.
- Wait until the printer is idle and silent before you proceed.
Note: HP recommends connecting the printer directly to a wall outlet rather than a surge protector or a power strip.
Update the printer firmware
Click here to download and install the latest firmware from your computer.
Click here to know different methods of updating printer firmware.
Also, perform step 4 from this document.
Let me know how this goes.
If you feel my post solved your issue, please click “Accept as Solution”, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
KUMAR0307
I am an HP Employee
08-07-2019 02:08 PM - edited 08-07-2019 02:15 PM
Unfortunately, these did not work, just to let you know, the previous recall was I think back in like 2016 or 2017 and my printer was purchased about this time as well. Is there any way to find out when my printer was made because there were documents online from HP that my printer model was eligible for the previous recall.
Edit: The link to the HP recall document is here: https://support.hp.com/us-en/document/c04839288
Best
-Jason
08-07-2019 03:01 PM
Thank you for the response. If the issue persists, please contact our HP Support team for Service Options as it could be a possible hardware issue:
1) Click on this link - https://support.hp.com/us-en/contact-hp?openCLC=true
2) Select your product type below.
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Select the appropriate option based on your preference.
6) Fill the web-form and proceed further.
Keep me posted for any other assistance.
KUMAR0307
I am an HP Employee
08-07-2019 03:46 PM
I'm sorry about bothering you with all this but I kind of got stuck after the 4th step. So after I entered my serial number and selected my country this is what I see:
What should I do from here?
This is what I see after entering my printer's serial number. I just drew across the serial number cause I didn't know if I should leave it or what...
08-08-2019 06:24 AM
To provide you with further instructions, I'd need a few details. I have sent you a private message, please check and revert.
- In order to access your private messages, click the private message icon on the upper right corner of your HP Forums profile, next to your profile Name or simply click on this link: https://h30434.www3.hp.com/t5/notes/privatenotespage
Keep me posted. Happy to help!
KUMAR0307
I am an HP Employee
