Hp ink tank 581 ink carriage belt broken and ink carriage leak off absorbing foam pads is destroyed due to mouse attack. Already I have removed chipped paper bits. When the ink carriage moves to right till last position, there is a foam pad down the carriage in a alot provided for the foam to fit.( As per manufacturer's design)
I want to get an quotation for through inspection and repair charges for this damage.
I would be grateful for this community to help and support with you best advice.
Thank You.
