Hp officejet 6960
I need help cleaning the printer head,
I have never done it, and YouTube ain't really helping, can you tell me how can I do this,
I don't want to damage this beauty,
Please I need an answer.
THANK YOU FOR READING
I'LL BE WAITING FOR YOUR ANSWER'S
1 REPLY 1
@Brillodelunax
Thank you for posting on HP Support Community.
Don't worry as I'll be glad to help, I have a few troubleshooting steps we could try to fix the issue:
  1. From the printer control panel, open the Setup menu.
  2. Open the Printer Maintenance menu.
  3. If necessary, open the Tools menu, and then touch Clean Printhead. A test page prints.
  4. Examine the test page. If the print quality is unacceptable, touch Clean Again to continue the next level of cleaning.
Click here: https://support.hp.com/in-en/document/c05076934 to know more about cleaning print head.
Hope this helps! Keep me posted for further assistance.
Please click “
Accept as Solution” if you feel my post solved your issue, it will help others find the solution.
ECHO_LAKE
I am an HP Employee
