How do i set up my pin number for an hp pagewide pro mfp 477 dw
2 REPLIES 2
Hello,
Hope you are well,  in order to generate a pin number please make sure the printer is connected thru network and get the IP address and access the embedded web server, by putting the IP address into the web browser URL.
Once you access, please go to settings tab > security > password settings and there you can set up a password for the printer.
Regards,
Regards,
I am an HP employee
There are a couple of different types of pins or passwords that can be configured, what exactly are you trying to do?
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
