Windows 11 Support Center. -
- HP Community
- Printers
- Images on document overlap, ink blocks and spikes, and light...
11-30-2022 01:18 PM
Product: HP DeskJet 1255 Printer
Operating System: Microsoft Windows 10 (64-bit)
I've run the HP Dr diagnostic tool and it says there's nothing wrong with the printer. I printed a test page and all is fine. Then I tried to print my document, a series of photos created in CorelDraw and the result is attached below. I tried to print PDF from Adobe Acrobat with similar results. I've tried to reset my printer, no change. The cartridges are properly installed, I'm using the correct paper. The button continues to flash, even though there are no documents waiting. Would appreciate any help before I trash the printer.
Ask the community
