Windows 11 Support Center. -
- HP Community
- Printers
- Re: LASER PRINTER SET UP FOR DUAL TRAY - PULL PAPER BASED ON...
07-07-2020 09:05 PM
I recently purchased the HP Laser Jet P3015 and set up Tray 2 with letter and Tray 3 with legal. I need to configure printing so that the laser jet knows when to pull/print on the letter and legal size all in one job automatically. Thank you!
07-07-2020 09:28 PM
If you have the trays on the printer set to the correct sizes, then it is your software that will determine whether the job prints on the appropriate paper. You just need to make sure that when you print the job you tell the driver to select paper based on the print job.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
07-08-2020 12:53 AM
What types of files are you printing?
