Windows 11 Support Center. -
- HP Community
- Printers
- Laser Jet Pro 500 color MFP M570dn won't print and touch scr...
10-06-2024 02:06 PM
I have a Laser Jet Pro 500 color MFP M570dn. The printer is not responding to the computer's print commands, the printer's touch screen doesn't respond and the orange and green icons keep flashing on and off. The computer print screen shows the print commands in the que. I've turned off and rebooted the printer several times and that doesn't fix the problem. Help!
10-06-2024 03:10 PM
Perform an engine test as documented here https://printcopy.info/index.php?mod=ts&brand=HP&model=LaserJet+M570dn+Pro+500+Color+MFP&tID=2300
If the engine test works then the most likely issue is a bad main board (formatter).
For information on sourcing and finding parts see here https://h30434.www3.hp.com/t5/Printers-Knowledge-Base/How-to-find-replacement-paper-trays-or-any-oth...
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
