Windows 11 Support Center. -
- HP Community
- Printers
- M477fdw Color Laser Jet Pro - grey dots on left side for eac...
10-11-2022 10:38 AM
All of the sudden little grey dots have started appearing for each printout. They are about 1 1/16" from the left hand side of the paper and 1 1/16" apart. I have attached a scan of one of my printouts (ignore the other stuff in the image, the glass is probably dirty) and you can see the dots clearly. I do not think it is a cartridge issue since I have the problem even when I "print" a blank sheet from Microsoft Paint.
Any help at all would be greatly appreciated. Thanks a lot.
Solved! Go to Solution.
10-11-2022 12:20 PM
Measure the dots carefully and compare the distance between dots to this chart.
@Valsimot is probably correct that you have a black cartridge issue. You can check the cartridge to see if there is any debris like a bit of label stuck in the cartridge.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
