Laser Jet Pro MFP M281 FDW
My error message is; SUPPLY PROBLEM. As a result, I can't print.
1 REPLY 1
Welcome to the "Fun HP new firmware update" club
The latest HP update blocks all 3rd party supplies
Dynamic security enabled printer. This Firmware includes dynamic security measures, which may prevent supplies with non-HP chips or circuitry from working now or in the future. More at: www.hp.com/go/learnaboutsupplies.
To use your printer with a 3rd party supply you will need to downgrade the latest firmware to the previous one.
I know how to do it, but HP probably wont be happy to tell you how. If you are tech savvy and google around a bit you can find the solution.
Just a electronics enthusiast trying to fix everything.
If this reply was helpful, click on the "yes" below to let others know. 🙂
If i solved your problem, please mark your thread solved:)
