IMAC
macOS 10.14 Mojave
I can't print.  I am receiving a message that says:  "Supply Problem"  - Does anybody knows how to fix this?
2 REPLIES 2
Hello  ,
Below are the steps that you need to follow in the order as mentioned ...
Disconnect the printer from the NETWORK
      If on wired network : Unplug the  Ethernet cable from back of the printer.
     If on wireless network : Power of the Wireless router. Turn off the printer.
Wait for 30 seconds. Turn on the printer.
If the printer is in READY state, on the printer front panel, go to Setup -> Network Setup -> Network Services -> IPv6 -> Off. Turn off the printer. Wait for 30 seconds and then turn on. Try printing , it should work.
Regards,
Jabzi
Give Kudos to say "thanks" by clicking on the "thumps Up icon" .
Click "Accept as Solution" if it solved your problem, so others can find it.
Although I am an HP employee, I am speaking for myself and not for HP.
Thanks - but this didn't work.
