Windows 11 Support Center. -
- HP Community
- Printers
- My HP 3772 won't copy. It will print but not copy.
07-07-2022
04:42 PM
- last edited on
07-10-2022
05:54 AM
by
Ric_ob
My HP 3772 will not copy. It just quit. It had been working earlier in the day. It will print from desktop or tablet but not when you just want to copy a document at the printer.
07-12-2022 08:01 AM
@dmc45, Welcome to the HP Support Community! I’m here to help.
I see that you are not able to make copies on the printer. The scanning/copy mechanism is different from printing. Hence, printing is not affected.
Reset the printer
- With the printer turned on, disconnect the power cord from the rear of the printer.
- Wait at least 60 seconds.
- Reconnect the power cord to the rear of the printer.
- Turn ON the printer, if it does not automatically turn on.
- Wait until the printer is idle and silent before you proceed.
Note: HP recommends connecting the printer directly to a wall outlet rather than a surge protector or a power strip.
Check the scanner bar functionality
Perform a visual test of the scanner mechanism to see if it is jammed.
- Remove any original documents or photos from the scanner glass.
- Lift the scanner lid slightly, and then press the Copy button or icon.
If the scanner light does not move or moves halfway or is not lit, the scanner mechanism is likely jammed/broken.
In this case,
- I've sent you a private message with further instructions to resolve this issue.
- In order to access your private messages, click the private message icon on the upper right corner of your HP community profile, next to your profile Name or simply click on this link: https://h30434.www3.hp.com/t5/notes/privatenotespage
Hope this helps! Let me know how it goes.
Click on the YES button to reply that the response was helpful and/or to say “Thank You”.
Have a great day!
KUMAR0307
I am an HP Employee
