Officejet Pro 8620
We were recently flooded out and had to leave home.  My printer was off the floor and wasn't damaged, but when the recovery company cleared everything out they binned the power cable for the printer.  I now need to buy a power cable for the printer but don't know exactly what I need.
it also seems that anything relevant is only available overseas via ebay.  Anyone know where I can buy the right power cable in the uk and get it in a few days?
If I have to write off the printer then that's what I'll do, but I'd prefer to save the money as it works fine and just get a cable instead.
Thanks for your help.
Andy
@Phats58
Do you mean power cord itself or including power supply  (A or B) ?
For B, you can buy standard cord at your local electrical stores. For A, you need the following part
          http://partsurfer.hp.com/Search.aspx?searchText=CM751-60045
You can order from there or use part # to buy elsewhere, including eBay
          https://www.ebay.com.au/itm/HP-CM751-60045-OEM-POWER-SUPPLY-OFFICEJET-PRO-8100-8600-PRINTER-with-AC-...
Regards.
BH
1 REPLY 1
@Phats58
Regards.
BH
