I own an HP OFFICEJET PRO 8600 Printer.  It has worked well for many years.  I took and extended vacation for 4 months and subletted my house during that time.  I recently returned and the printer is not working.  The screen says "There is a problem with the printer or ink system.  Turn the printer off, and then on.  Of problem persists, contact HP."  I turned the printer on and off several times, as well as replaced the ink.  The printer still does not work.  I called HP but it would not let me get through to a person and instead directed me here.  My subletter damaged many items in my house and I'm trying to determine if this is one of them or a coincidence.  I don't see any external damage, but the power cord was missing when I returned and I had to buy a new one.  What do you think happened?  What should I do to fix the printer.  I don't need legal advice as I've already received that.
1 REPLY 1
Hi @DrBob15, @Hope101,
I see that you are facing an issue with your printer that has a ink system error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
