Windows 11 Support Center. -
- HP Community
- Printers
- Officejet Pro 6830 keeps saying "Problem with printhead"
12-05-2016 12:56 PM
Printer keeps saying "problem with printhead"; changed ink cartridges because they were low (thought that may be the problem, it wasn't); pulled plug from outlet, didn't work; pulled plug from rear of printer, didn't get rid of message;
won't print at all or make copies
Solved! Go to Solution.
12-05-2016 01:41 PM
You will need to contact HP for a replacement as described in the document here.
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click "Yes" to the "Was this post helpful" question.
12-05-2016 01:41 PM
04-01-2018 08:04 AM
04-01-2018 08:06 AM
Same answer as above - you will need to have the printer serviced or replaced.
