Officejet Pro 8610
Officejet Pro 8610 Damaged Cartridge Problem. Tried firmware, unplugging, reseating cartridges, cleaning contacts.
Is it supposed to indicate which cartridge is a problem, because the oinly indicator I see would indicate to me it thinks ALL the cartridges are bad.
3 REPLIES 3
@sflesch
Welcome to HP forums, I see that you are getting cartridge error.
Update the printer firmware.
  1. From the home screen on the printer control panel, touch the HP ePrint icon .
  2. Wait for the printer to connect to the HP ePrint server.
    When the printer connects to the server, the HP ePrint status displays.
  3. Touch Settings on the bottom left corner of the screen.
  4. Touch Printer Update, and then touch Check for Update Now.
Reseat the printhead up to three times.
  1. Slip your fingers into the slot on the left side of the printer, and then pull forward to open the cartridge access door. The carriage moves to the left side of the printer. Wait until the carriage is idle and silent before proceeding.
    Figure : Open the cartridge access door
  2. Image: Open the cartridge access door.
  3. Slot on the left side of the printer
  4. Unplug the power cord from the rear of the printer. Unplugging the printer prevents the carriage from moving.
  5.    WARNING:
    You must disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  6. Lift the carriage latch.
    Figure : Lift the carriage latch
    Image: Lift the carriage latch.
  7. Grasp the sides of the printhead, and then slightly lift the printhead without fully removing it from the carriage.
    Figure : Slightly lift the printhead
    Image: Slightly lift the printhead.
  8. Reinsert the printhead into the carriage to reseat it. As you guide the printhead into the carriage, it lowers into the carriage as it seats.
    Figure : Reseat the printhead
    Image: Reseat the printhead.
  9. Gently rock the printhead to the left and right to make sure that the printhead fully seats in the carriage.
  10. Lower the carriage latch.
    Figure : Lower the carriage latch
    Image: Lower the carriage latch.
  11. Verify that the carriage latch is down.
    Figure : Carriage latch positions
    1.
      Image: Carriage latch positions.
      Carriage latch is up
    2. Carriage latch is down
  12. Close the cartridge access door.
  13. Reconnect the power cord to the rear of the printer.
  14. If the printer does not turn on by itself, press the Power button to turn it on.
  15. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
You can refer to this HP document for more assistance:- Click here
Let me know how it goes.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
Hi. I did all that. It still comes up with the error. Is it supposed to indicate which cartridge is the issue?
@sflesch
Thanks for the reply.
I appreciate your time and effort.
As we diagnosed and found it is a hardware issue with the product. I will share you few details through a private message about the service options dedicated to your product, please watch your inbox for more information.
Cheers.
Sandytechy20
I am an HP Employee
