HP OfficeJet Pro 9025e All-in-One Printer
Having problems with our Officejet Pro 9025e printer.
Getting "Problem with Supply System" after replacing the Cyan cartridge with a new HP cartridge.
Online troubleshooting has not helped.
Thanks!
1 REPLY 1
Hi @plwj,
I'm sorry to hear that you're experiencing issues with your Officejet Pro 9025e printer. The "Problem with Supply System" error can be frustrating, but there are a few steps you can take to troubleshoot and hopefully resolve the issue. Here are some suggestions.
Check Cartridge Installation:
  • Ensure that the Cyan cartridge is securely and correctly installed. Open the printer cover, remove the cartridge, and then reinsert it firmly until it clicks into place.
Restart the Printer:
  • Turn off your printer, wait for about 30 seconds, and then turn it back on. This simple step can sometimes resolve temporary issues.
Update Firmware:
  • Check if there is a firmware update available for your printer on the HP support website. Updating the firmware can often fix bugs and improve the overall performance of the printer.
Clean Cartridge Contacts:
  • Turn off the printer and disconnect it from the power source.
  • Remove the Cyan cartridge.
  • Clean the electrical contacts on both the cartridge and the printer with a lint-free cloth.
  • Reinstall the cartridge and turn the printer back on.
Check for Obstructions:
  • Make sure there are no obstructions in the cartridge area that may be preventing proper contact.
Use Genuine HP Cartridges:
  • Ensure that you are using genuine HP cartridges. Third-party or refilled cartridges may not be recognized properly by the printer.
Perform a Printer Reset:
  • Turn off the printer.
  • Disconnect the power cord from the back of the printer.
  • Wait for about 60 seconds.
  • Reconnect the power cord and turn on the printer.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
