Windows 11 Support Center. -
- HP Community
- Printers
- Oil leaking on paper in paper tray
04-16-2020 09:47 AM
I have oil leaking onto the paper in the tray. When I print the first few sheets of paper have an oily smudge at the top right corner of the paper. Where is it coming from and how do I repair it?
04-19-2020 11:22 AM
Hi @wdv18
As this is a hardware issue, I'd suggest you Contact HP in your region regarding the service options for your printers
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile Name, you should see a little blue envelope, please click on it.
Have a great day!
