Windows 11 Support Center. -
- HP Community
- Printers
- Power LED blinking how to reset the m28w
11-13-2020 11:23 AM
Please semd me the instructions to reset the printer. It is not responding, the Power LED is blinking, the LCD shows "HP" only.
Solved! Go to Solution.
11-14-2020 07:35 AM
Hi @Esseii,
I'd like to help!
We can perform a factory defaults on the printer to resolve the issue
- The reset instructions are specific for your printer and performing those steps on a different printer may corrupt the device.
- I've sent you a private message with reset instructions, follow the reset instruction to perform a full reset and re-initialize the printer.
- In order to access your private messages, click the private message icon on the upper right corner of your HP Forums profile, next to your profile Name or simply click on this link: https://h30434.www3.hp.com/t5/notes/privatenotespage
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
11-14-2020 07:35 AM
Hi @Esseii,
I'd like to help!
