HP DeskJet 3772 All-in-One Printer
The power button blinks continuously.
How can I reset it?
1 REPLY 1
@Rick2222
Welcome to the HP support community.
I understand that the power light is blinking on the printer, I am glad to assist you.
Perform a power reset , Reset the printer to recover from printer errors or failures.
  1. Turn on the printer, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Wait at least 30 seconds.
  5. Plug back the power cable straight to a wall outlet and printer without any surge protector.
  6. Turn on the printer.
Refer to this HP document to fix the issue:- Click here
Keep me posted.
If this helps, please mark the public post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
