Office jet 3830
Microsoft Windows 10 (32-bit)
printer display don’t turn on, but power supply light looks ok
1 REPLY 1
Hi @amolaito,
I'd like to help!
I understand that the printer display is blank and will not turn on.
Try the below suggestions-
Solution one: Turn the printer off and then on again
Follow these steps to restart the printer.
  1. Press the Power button to turn off the printer.
  2. Wait 60 seconds, and then press the Power button to turn on the printer.
Solution two: Plug the printer directly into a wall outlet
Make sure that the printer is properly connected to a suitable power source.
  2. Disconnect the printer's power cord from any power strips or surge suppressors and then plug it directly into a grounded wall outlet.
  3. Press the Power button to turn on the printer, and then try to use the menu to check if the printer control panel is functional.
Solution three: Reset the printer
Follow the steps below to reset the printer.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    NOTE:
    HP recommends plugging the printer directly into a wall outlet.
 Also, try updating the printer's firmware -HP Printers - Updating or Upgrading Printer Firmware
If the issue persists, I'd suggest you contact HP in your region regarding the service options for your printer
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
