Windows 11 Support Center. -
- HP Community
- Printers
- Print destination problem
09-22-2020 02:06 PM
I bought a new HP laptop and it's not letting me print documents, it only wants to save them to a pdf file or google drive, I never had this trouble with my dell laptop, it's the same printer. What do I do?
09-25-2020 09:37 AM
I reviewed your post and I understand that you are facing issues printing documents.
Don’t worry, I assure you I will try my best to get this sorted.
Are you able to make a copy?
Meanwhile, I recommend you root uninstall the printer and then reinstall it and check whether the issue is resolved.
Here is how it is done.
1.) In Windows, search for and open Programs and features
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Devices and printers
5.) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose 'Delete' or 'Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
13.) Restart the PC
14.) Download and install the printer software from the below link.
Let me know how it goes and you have a great day!
P.S: Welcome to the HP Support Community 😊
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
Stay Home – Stay Safe
The_Fossette
I am an HP Employee
