Example: Pavilion 65XXHP OfficeJet 6962
Microsoft Windows 7 (64-bit)
Printer 6962 will not copy and when picture sent from computer  does not print color but will print black/white.
1 REPLY 1
@Barry398, Welcome to HP Support Community!
Check the settings on the application you are trying to print from. Refer to this document HP Printers - Print Driver Settings Guide (Windows) for help.
Update the printer firmware
HP regularly releases new printer firmware versions with product enhancements or issue fixes. Depending on your printer, apps on the printer control panel might also receive updates. Update firmware and apps on a regular basis to make sure you are getting the most out of your printer. Refer to this link for help.
Also, I recommend you delete the driver and root level and retry, follow the steps below:
1)In Windows, search for and open Programs and features
2) Select your HP Printer
3) Select Uninstall
4) In Windows, search for and open Devices and printers
5) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose ‘Delete’ or ‘Remove Device’
6) Open up the run command with the “Windows key + R” key combo.
7) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe”
😎 Click on the “Drivers” tab
9) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10) Select Ok
11) Select Apply and Ok on the Print Server Properties windows
12) Close Devices and Printers.
Now, download and install the full-featured software from here.
If the issue persists, try installing the Windows built-in drivers. Here is how you do it:
•    Go to Control Panel - Devices and Printers - Click on "Add printer" and follow the on-screen instructions.
•    When the page prompts for the drivers, select "Windows update". The driver list will be updated.
•    Click HP, Hewlett Packard, or Hewlett-Packard in the Manufacturer pane, and then click the name of your printer in the Printers pane.
Refer to this document HP Printers - Installing and Using the Windows Built-in Print Driver for help.
Keep me posted.
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
TEJ1602
I am an HP Employee
