I purchased HP107W laser printer a few months ago, so it's under warranty.  The power lead into printer seemed a little loose, but all worked fine.  I have not tugged the lead, squashed it, or manhandled it in any way.  I successfully printed a few days ago but yesterday, when I plugged it in, it seemed much looser and the blue 'power on' light wouldn't stay on.  Has anyone else experienced similar?  Can anyone advise if a replacement cable would solve the issue?  I can't imagine HP would accept that it's a fault on their part, so, if a new cable would fix it, I wonder if that's my best way forward, but I don't want to fork out for that if it could be a bigger issue.  P.S.  Having tried it a few times this evening, it won't connect at all.
Thanks for any advice.
1 REPLY 1
Hi @hope4me,
I understand that you are facing issues with a loose power cable. I'd like to help!
This situation will need some additional support from our internal teams in HP. For that to happen, we will give you additional instructions/information via Private Message.
Please check your inbox on the forums page for private message.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution button, that'll help us and others see that we've got the answers!
Nal_NR-Moderator
I am an HP Employee
