Windows 11 Support Center. -
- HP Community
- Printers
- Printer is not taking paper inside for print
07-20-2020
12:36 AM
- last edited on
07-20-2020
08:57 AM
by
BiancaS
My printer is not taking paper for print,although I put enough paper init,
Printer is HP LASERJET 1022
SERIal num: [Personal Information Removed]
07-22-2020 08:58 AM
Hi @Godara1998,
I understand you are facing paper feed issue, I'd like to help
Try the below solutions to resolve the issue -
Solution one: Turn off manual feed mode
Follow these steps to make sure manual feed mode is Off.
Press the Power button (
) to make sure the product is on. The green power light is lit when the product is on.
Open the Properties window for the product:
Windows XP: Click Start, click Printer and Faxes, right-click HP LaserJet 10xx series, and then select Properties.
Windows Vista: Click the Windows icon (
), click Control Panel, click Hardware and Sound, click Printer, right-click HP LaserJet 10xx series, and then select Properties.
Windows 2000: Click Start, click Printer and Faxes, right-click HP LaserJet 10xx series, and then select Preferences.
In the Properties window, select the Paper/Quality tab, select Automatic or the appropriate tray from the Source is: drop-down list, and then click Apply.
NOTE:
Do not select Manual Feed from the drop-down list.
Click Apply to accept the settings, and then click OK to exit the Properties window.
Try the print job again.
If these steps resolved the issue, you do not need to continue troubleshooting.
If the issue persists, continue to the next solution.
Solution two: Check the paper guides on the input tray
Follow these steps to check for the proper adjustment of the paper guides on the input tray. If the paper guides are too tight, then the paper might be held in the tray and not allowed to feed into the product.
Remove all paper from the input tray.
Fan the sheets of paper, and then tap the edges of the stack on a flat surface to align the edges.
Pull the paper guides to their outermost position.
Figure : Pull out the paper guides
Load the paper stack into the input tray with the top forward and the print-side face up.
Push the paper guides inward until they rest firmly against the edges of the stack.
Figure : Adjust paper guides
Solution three: Clean the pickup roller
Dirt or grime build up on the pickup roller can cause the paper to feed into the product incorrectly or not at all. Follow these steps to clean the pickup roller.
CAUTION:Failure to complete this procedure correctly might damage the product.
) to turn off the product.
Disconnect the power cord from the back of the product.
Figure : Disconnect the power cord
Wait for the product to cool down.
Open the print cartridge door, and then remove the print cartridge.
CAUTION:
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.
Figure : Remove the print cartridge
Find the pickup roller.
Figure : Pickup roller
Pickup roller
Release the small, white tabs on either side of the pickup roller, and then rotate the pickup roller toward the front of the product.
Figure : Release the pickup roller tabs
Gently pull the pickup roller up, and then out.
Figure : Remove the pickup roller
Dab a lint-free cloth in rubbing alcohol (isopropyl alcohol), and then scrub the pickup roller.
Figure : Rubbing alcohol and clean cloth
WARNING:
Rubbing alcohol is flammable. Keep the rubbing alcohol and cloth away from any open flame or heat source. Before you close the product, allow the rubbing alcohol to dry completely.
NOTE:
In certain areas of California, air pollution control regulations restrict the use of liquid Isopropyl Alcohol (IPA) as a cleaning agent. In those areas of California, please disregard the previous recommendations and use a dry, lint-free cloth. The cloth may be moistened with water if desired.
Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt.
Figure : Wipe the pickup roller with a dry cloth
Allow the pickup roller to dry completely before you reinstall it in the product.
Position the pickup roller in the slot. The circular and rectangular slots on each side will prevent you from installing the roller incorrectly.
Figure : Position the pickup roller
Rotate the top of the pickup roller away from you until both sides snap into place.
Figure : Snap the roller into place
Reinstall the print cartridge, and then close the print cartridge door.
Figure : Reinstall the print cartridge
Reconnect the power cord to the back of the product.
Figure : Reconnect the power cord
) to turn on the product.
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
