Windows 11 Support Center. -
- HP Community
- Printers
- Printer won't print in colour and will not print both sides ...
07-03-2018
07:54 AM
- last edited on
07-03-2018
04:26 PM
by
rick-s
My HP EN VY 4520 all in one will not print in colour nor will it print both side automatically
Solved! Go to Solution.
07-04-2018 05:11 PM
I read your fabulous description. Thanks for the update. It is splendid to hear from you again. Your efforts and patience are appreciated. Your immaculate attitude, terrific temperament coupled with profound technical skills are commendable. Kudos to you for that. 🙂 As @Jeet_singh I am responding on his behalf.
For now, please try these steps:
- Uninstall the printer from "programs and features" which can be accessed by doing a right-click on the Windows button (Please have the printer Off and disconnected during uninstallation.)
- Check in device manager, if the printer is listed there, please delete it. (Right click on the Windows button to access device manager)
- Go to devices and printers, in control panel and select any printer listed there and you will get some options on the top.
- Click on print server properties.
- You will get a popup, click on the drivers tab and delete all the HP printer drivers listed there if any.
- Delete all the instances of your printer listed in devices and printers.
- Restart the PC.
- Once the PC is on the desktop, press Win + R, it would bring a Run dialog box,
- Type %temp% in the run box and click Ok or hit the Enter button.
- It would bring up the temporary files folder. Delete the files in the folder (You might not be able to delete all the files).
- If possible, delete the printer from the registries using Regedit or using any other 3rd party application.
- Ignore the Regedit option if it cannot be done.
- Restart the PC again.
Then download the latest full feature driver from https://hp.care/2NrqbOb and install it on the computer after selecting the correct operating system.
Connect the printer to your computer only when the setup prompts for the printer.
This should fix the issue.
Perform all these steps patiently as it is critical to resolving the issue. Good luck to you. I will keep a watch for your response. Please remember that we are not overloading you with a lot of troubleshooting steps. Instead, we are as eager as you are to get the situation corrected.
Let me know how it goes and you have a great day!
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles.
Take care and have a blessed week ahead. 🙂
DavidSMP
I am an HP Employee
07-03-2018 05:08 PM
Thank you for posting on HP Support Forums. It is a great place to find the help you need, from other users, HP experts, and other support personnel. I see from your post that you are having issues while printing in color from your HP Envy 4520 printer. Don't worry we'll work together to help you find a solution.
To provide you with an accurate solution, I'll need a few more details:
Did the issue happen after replacing the ink cartridges?
Are you using genuine HP Ink cartridges or refilled cartridges?
Have you followed any troubleshooting before posting this on HP Forums?
Are you able to make a copy from the printer?
Let's try to perform a Hard reset on the printer and make sure that the printer is connected directly to the wall outlet and not to the surge protector.
Remove all the ink cartridges and then try to perform a hard reset on the printer.
With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
Remove USB cable, if present.
Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord and then plug back the power cord to the printer.
Turn on the printer and wait till warm-up period finishes and the printer is idle.
Now insert the ink cartridges and then try to print a test page and check if it works.
Let’s first try and make a colour “photocopy” to determine whether the issue is with the printer or not. Place a document on the scanner glass and choose “Copy” option. If the printer is making a good copy, then the printer hardware is fine.
Could you please respond to this post with the details and with the results of the troubleshooting for further assistance.
Eagerly waiting for your response!
I hope you have a good day ahead,
And Feel free to ask your queries as this forum has some of the best people in the world available and ready to help.
Regards,
Jeet_Singh
I am an HP Employee
07-04-2018 05:11 PM
- Restart the PC.
DavidSMP
I am an HP Employee
07-06-2018 05:25 PM
Thank you for the update,
I appreciate your time and efforts,
I'm glad to hear you found the solution you were looking for.
Thanks for taking the time to let the community know about the solution.
You've been great to work with and it has been a genuine pleasure interacting with you.
I hope both you and your product works great and remain healthy for a long time 😉
To simply say thanks for my efforts to assist you, please click the "Thumbs Up" button to give me a Kudos.
And mark my post as Accepted Solution to help others find a similar solution as you have.
Take care now and do have a fabulous week ahead. 🙂
Regards,
Jeet_Singh
I am an HP Employee
