I have a fairly old but very good OfficeJet all in one printer which has always worked perfectly in the past. Following my latest (genuine HP) cartridge change, I got the error message Printer Failure: There is a problem with the printer or ink system. I have gone through all the steps recommended in the HP support articles, excluding the one involving lifting/dropping/wiggling the printer head as mine is not the type with a release catch, but to no avail. Also the serial number is not recognised on the official HP support site so I can't get into contact with anyone there.
Advice please? Really hoping this is not the end of the road - I've just spent over £100 on a new set of cartridges!
1 REPLY 1
Hi @NikkiRG10,
Welcome to the HP Support Community!
I understand how frustrating this is, especially after installing a new set of genuine HP cartridges and then immediately receiving a “Printer Failure: There is a problem with the printer or ink system” message.
Since you have already completed most of the recommended troubleshooting, including the steps that apply to the printhead, I would suggest not attempting to lift, drop, or force the printhead if your particular carriage does not have the applicable release/latch mechanism. HP's troubleshooting instructions only recommend reseating the printhead on models with a removable printhead and carriage latch.
Please try these final checks:
1. Perform a complete power reset
  • Turn the printer on.
  • Disconnect the power cord from the back of the printer.
  • Disconnect it from the wall outlet.
  • Wait at least 60 seconds.
  • Connect the printer directly to a wall outlet.
  • Reconnect the power cord and turn the printer on.
  • Check whether the error returns.
2. Check the new cartridges
  • Since the problem appeared immediately after the cartridge replacement:
  • Remove each cartridge.
  • Check for any leakage, damage, or obstruction around the cartridge.
  • Make sure each cartridge is installed in its correct color-coded position and is seated firmly.
  • Reinstall the cartridges and allow the printer to complete its initialization.
  • HP specifically recommends checking cartridges for leaks when this error occurs.
3. If the error remains
If the printer continues to report the same printer/ink-system failure after the reset and cartridge checks, the issue may be with the printhead or the printer's ink system, rather than the computer or printer driver.
If possible, please provide the exact error message as displayed on the printer screen, including any error code, and a photo of the printer's display. That will help us determine the appropriate next step for the OfficeJet Pro 8600 Plus.
Best regards,
Kuroi_Kenshi
I'm an HP Employee.
If this reply helped resolve your issue, please select the Accept as Solution as it helps others in the community quickly find the answer they’re looking for.
And if you found this reply helpful, clicking Yes below is a great way to let us know we’re providing the support you need, as it encourages us to keep improving and sharing helpful guidance.
