HP Officejet Pro 8615
Mac OS X 10.11 El Capitan
HELP :  Printhead error message on my HP Officejet Pro 8615"Printhead seems to be missing,not detected,incorrectly installed or incompatible" but i don't understand because i didn't change my cartridges as they are still full and the printer worked perfectly yesterday !!
I asked HP they told me i had to buy a new printer !!
Can someone help me ? Thanks
Delphine
1 REPLY 1
@Dafroots, Welcome to HP Support Community!
I would recommend you to reset the printing mechanism first.
Below are the steps you can follow:
  • Turn the printer on, if it is not already on.
  • Wait until the printer is idle and silent before you continue.
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the rear of the printer.
  • Turn on the printer, if it does not automatically turn on.
  • Wait until the printer is idle and silent before you proceed.
If the issue persists, try following the troubleshooting steps from this document.
Let me know if this helps.
Cheers 🙂
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
TEJ1602
I am an HP Employee
