hp officejet pro 8600
Microsoft Windows 7 (64-bit)
My screen reads problem with printer or ink system  It has also indicatedprinthead appears to be missing not detected or incorrectly installed.
1 REPLY 1
@TeddyJim,
Welcome to HP Support Community,
Have you tried to reseat the printhead three times?
Have you checked for any obstructions inside the printer?
Are you able to move the carriage freely?
In the meantime, let's try these steps here:
Let's start off by updating the printer firmware. If your printer connected wirelessly, make sure to temporary connect the device with USB and then follow the link to install the latest firmware update on your printer from our HP support website. Alternatively you can also try to update the printer firmware directly from the printer control panel.
For more details on how to update, please use this link: HP Printers - Updating or Upgrading Printer Firmware
If the issue persists, I would suggest here is to do a hard reset on the printer and make sure that the printer is connected directly to the wall outlet and not to the surge protector.
With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
Remove USB cable, if present.
Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord and then plug back the power cord to the printer.
Turn on the printer and wait till warm-up period finishes and the printer is idle.
Next thing, I would suggest here is to follow the steps suggested in the support document for - HP OfficeJet Printers - Resolving 'Missing or Failed Printhead' Error
Alternatively, you can also follow the steps from this link: HP Officejet 8600 Printers - 'Ink System Failure' Error (This document also has steps for updating the printer).
Let me know how it goes!
Jeet_Singh
I am an HP Employee
